Scottydoggs
Killa Bee
http://www.grandprixforums.net/thre...-oil-pan-rear-cover-seal-engine-mount-etc-etc some where in this thread is the tq spec.
look up whats called a lower conversion kit. has all them gaskets plus the oil pan and a few others for about 30 bucks. ( no head gaskets or lim. just the bottom of the engine)
change the rear main seal, not the front crank seal. the odds of that one leaking are real. best to leave it alone.
the rear cover you want to rtv the bottom 2 inches of the gasket on both sides, the pan gasket do rtv on both sides of the gasket, i did a smear on the block and the pan.
that rear cover is a very low tq, the bolts maybe hand tight right now. add a dot of blue loctight to these bolts to keep them in.
felpro vc gaskets, with grommets.
heres a pic i just found, see the bottom of the block the orange line is the oil pan, the two sides from the pan up, rtv just past that first bolt hole.
im no fan the pan being on before the rear cover, when you put the cover on that rtv is just gonna get wiped off by the cover.
and theres no need to trv all the way up like in the pic.
that plug is in the tranny, it can stay, off the bottom of the p/s pump is the knock sensor wire clipped to it, in line is a small plug tot he rear kr sensor harness.
once the starter is off you can get to the tc bolts.
have a jack under the tail shaft of the tranny, aka pass side to hold it up. then jack it up so its a bit higher, makes the engine coming off the tranny easier. leave the jack there after the engine is removed to keep it up, or it hits the floor.
taking the two bolts out of the p/s pump is ok, the leaving them in the pump keeps them safe.
the ac you just unbolt it from the front of the engine, and remove the bracket from its back side. lay the compressor on the frame.
kr sensor and the oil pressure, thats it back there. and you got the green one off, thats the o/p
the harness up top just flip it all to the d/s. its only on the top, nothing goes down lower. the harness is clipped to the bracket in the middle rear tho
