Re: Pressure Control Solenoid Replacement
The job starts tomorrow around 4, and can carry on to Saturday if needed, the weather looks good. Wish me luck.
Good reference material:
Component Resistance
[TABLE="class: repair_table"]
[TR]
[TH="class: rt_leaf"]Component[/TH]
[TH="class: rt_leaf"]Pass Thru Pins[/TH]
[TH="class: rt_leaf"]Resistance at 20°C (68°F)[/TH]
[TH="class: rt_leaf"]Resistance at 88°C (190°F)[/TH]
[TH="class: rt_leaf"]Resistance to Ground (Case)[/TH]
[/TR]
[TR]
[TD="class: rt_leaf"]1-2 Shift Solenoid Valve[/TD]
[TD="class: rt_leaf"]A, E[/TD]
[TD="class: rt_leaf"]19-24 Ω[/TD]
[TD="class: rt_leaf"]24-31 Ω[/TD]
[TD="class: rt_leaf"]Greater than 250 K Ω[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]2-3 Shift Solenoid Valve[/TD]
[TD="class: rt_leaf"]B, E[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]Torque Converter Clutch Pulse Width Modulation Solenoid Valve[/TD]
[TD="class: rt_leaf"]T, E[/TD]
[TD="class: rt_leaf"]10-12 Ω[/TD]
[TD="class: rt_leaf"]13-15 Ω[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]Pressure Control Solenoid Valve[/TD]
[TD="class: rt_leaf"]C, D[/TD]
[TD="class: rt_leaf"]3-5 Ω[/TD]
[TD="class: rt_leaf"]5-6 Ω[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]Automatic Transmission Input Speed Sensor[/TD]
[TD="class: rt_leaf"]S, V[/TD]
[TD="class: rt_leaf"]820-1020 Ω[/TD]
[TD="class: rt_leaf"]1132-1428 Ω[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]Automatic Transmission Fluid Temperature Sensor[/TD]
[TD="class: rt_leaf"]* M, L[/TD]
[TD="class: rt_leaf"]3164-3867 Ω[/TD]
[TD="class: rt_leaf"]225-285 Ω[/TD]
[TD="class: rt_leaf"]Greater than 10 M Ω[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]Vehicle Speed Sensor[/TD]
[TD="class: rt_leaf"] A, B
VSS CONN[/TD]
[TD="class: rt_leaf"]1650-2200 Ω[/TD]
[TD="class: rt_leaf"]2360-3180 Ω @ 150°C (302°F)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf, colspan: 5"] * The resistance of this device changes rapidly with temperature.[/TD]
[/TR]
[/TABLE]
Fluid Capacity Specifications
[TR]
[TH="class: rt_leaf"]Application[/TH]
[TH="class: rt_leaf, colspan: 2"]Specification[/TH]
[/TR]
[TR]
[TH="class: rt_leaf"]Metric[/TH]
[TH="class: rt_leaf"]English[/TH]
[/TR]
[TR]
[TD="class: rt_leaf"]Bottom Pan Removal[/TD]
[TD="class: rt_leaf"]7.0 liters[/TD]
[TD="class: rt_leaf"]7.4 quarts[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]Complete Overhaul[/TD]
[TD="class: rt_leaf"]9.5 liters[/TD]
[TD="class: rt_leaf"]10.0 quarts[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"]Dry[/TD]
[TD="class: rt_leaf"]12.7 liters[/TD]
[TD="class: rt_leaf"]13.4 quarts[/TD]
[/TR]
[/TABLE]
Case Side Cover Bolts
[TR]
[TH="class: rt_leaf"][/TH]
[/TR]
[TR]
[TD="class: rt_leaf"](56)[/TD]
[TD="class: rt_leaf"]Side Cover Bolt/Screw M8 X 1.25 X 25.0 (9)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](57)[/TD]
[TD="class: rt_leaf"]Side Cover Bolt/Screw M8 X 1.25 X 21.0 (4)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](58)[/TD]
[TD="class: rt_leaf"]Side Cover Bolt/Screw M8 X 1.25 X 24.0 (4)[/TD]
[/TR]
[/TABLE]
Oil Pump Bolts
[TR]
[TD="class: rt_leaf"](374)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 65.0 (3)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](375)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 60.0 (3)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](376)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 30.0 (1)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](377)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 45.0 (2)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](378)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 55.0 (3)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](379)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 95.0 (1)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](380)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M8 X 1.0 X 90.0 (1)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](381)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 20.0 (2)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](384)[/TD]
[TD="class: rt_leaf"]Control Valve Body Bolt/Screw M6 X 1.0 X 85.0 (1)[/TD]
[/TR]
[/TABLE]
Case Cover Bolts
[TR]
[TD="class: rt_leaf"](433)[/TD]
[TD="class: rt_leaf"]Case Cover Bolt/Screw TORX® Plus Special M6 X 1.0 X 32.0 (1)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](434)[/TD]
[TD="class: rt_leaf"]Case Cover Bolt/Screw M6 X 1.0 X 40.0 (3)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](435)[/TD]
[TD="class: rt_leaf"]Case Cover Bolt/Screw M8 X 1.25 X 50.0 (3)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](436)[/TD]
[TD="class: rt_leaf"]Case Cover Bolt/Screw M6 X 1.0 X 30.0 (3)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](805)[/TD]
[TD="class: rt_leaf"]Case Cover Bolt/Screw M6 X 1.0 X 16.0 (1)[/TD]
[/TR]
[/TABLE]
Case Cover Assembly
[TR]
[TD="class: rt_leaf"](401)[/TD]
[TD="class: rt_leaf"]Case Cover[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](402)[/TD]
[TD="class: rt_leaf"]Manual Valve Link[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](403)[/TD]
[TD="class: rt_leaf"]Manual Valve Link Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](404)[/TD]
[TD="class: rt_leaf"]Manual Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](405)[/TD]
[TD="class: rt_leaf"]Low Blow Off Ball Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](406)[/TD]
[TD="class: rt_leaf"]Low Blow Off Ball Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](409)[/TD]
[TD="class: rt_leaf"]Left Side Axle Oil Seal Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](410)[/TD]
[TD="class: rt_leaf"]Control Valve Body Alignment Sleeve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](411)[/TD]
[TD="class: rt_leaf"]Bore Plug[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: rt_leaf"](412)[/TD]
[TD="class: rt_leaf"]Orificed Cup Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](414)[/TD]
[TD="class: rt_leaf"]Actuator Feed Limit Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](415)[/TD]
[TD="class: rt_leaf"]Actuator Feed Limit Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](416)[/TD]
[TD="class: rt_leaf"]Actuator Feed Limit Valve Spring Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](417)[/TD]
[TD="class: rt_leaf"]Ball Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](418)[/TD]
[TD="class: rt_leaf"]TCC Blow Off Ball Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](420a)[/TD]
[TD="class: rt_leaf"]Low Blow Off Ball Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](420b)[/TD]
[TD="class: rt_leaf"]TCC Blow Off Ball Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](421)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Piston Cylinder[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](422)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Piston Cylinder O-Ring Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](423)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Piston Outer Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](424)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Piston Inner Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](426)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Piston Pin[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](427)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Piston Oil Seal Ring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](428)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Piston[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](429)[/TD]
[TD="class: rt_leaf"]Case Cover Lower Gasket[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](430)[/TD]
[TD="class: rt_leaf"]Case Cover Upper Gasket[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](431)[/TD]
[TD="class: rt_leaf"]Front Wheel Drive Shaft Bearing Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](432)[/TD]
[TD="class: rt_leaf"]Fourth Clutch Shaft Thrust Washer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](440)[/TD]
[TD="class: rt_leaf"]Input Speed Sensor Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](441)[/TD]
[TD="class: rt_leaf"]Input Speed Sensor Clip[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](514)[/TD]
[TD="class: rt_leaf"]Drive Sprocket/Case Cover Thrust Washer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](526)[/TD]
[TD="class: rt_leaf"]Case Cover Dowel Pin[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
Oil Pump Assembly
[TR]
[TD="class: rt_leaf"](201)[/TD]
[TD="class: rt_leaf"]Pump Cover[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](202)[/TD]
[TD="class: rt_leaf"]Oil Pump Body[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](205)[/TD]
[TD="class: rt_leaf"]Oil Pump Cover Bolt/Screw M6 X 1.0 X 20.0 (1)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](209)[/TD]
[TD="class: rt_leaf"]Oil Pump Vane Ring[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: rt_leaf"](210)[/TD]
[TD="class: rt_leaf"]Oil Pump Selective Rotor[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](211)[/TD]
[TD="class: rt_leaf"]Oil Pump Selective Vane[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](212)[/TD]
[TD="class: rt_leaf"]Oil Pump Slide Oil Seal Ring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](213)[/TD]
[TD="class: rt_leaf"]Oil Pump Slide O-Ring Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](214)[/TD]
[TD="class: rt_leaf"]Oil Pump Selective Slide[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](215)[/TD]
[TD="class: rt_leaf"]Oil Pump Slide Pivot Pin[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](219)[/TD]
[TD="class: rt_leaf"]Oil Pump Outlet Screen Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](220)[/TD]
[TD="class: rt_leaf"]Oil Pump Slide Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](221)[/TD]
[TD="class: rt_leaf"]Oil Pump Slide Seal Support[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](222)[/TD]
[TD="class: rt_leaf"]Oil Pump Prime Outer Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](223)[/TD]
[TD="class: rt_leaf"]Oil Pump Prime Inner Spring[/TD]
[/TR]
[/TABLE]
Control Valve Body Assembly (1 Of 2)
[TR]
[TD="class: rt_leaf"](301)[/TD]
[TD="class: rt_leaf"]Control Valve Body Machined[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](302)[/TD]
[TD="class: rt_leaf"]Line Boost Valve and Bushing Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](303)[/TD]
[TD="class: rt_leaf"]Line Boost Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](304)[/TD]
[TD="class: rt_leaf"]Line Boost Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](305)[/TD]
[TD="class: rt_leaf"]TCC PWM Solenoid Valve O-Ring Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](306)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](307)[/TD]
[TD="class: rt_leaf"]Pressure Control Solenoid Valve O-Ring Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](309)[/TD]
[TD="class: rt_leaf"]Reverse Boost Valve Bushing[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](310)[/TD]
[TD="class: rt_leaf"]Reverse Boost Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](311)[/TD]
[TD="class: rt_leaf"]Pressure Regulator Valve Spring Outer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](312)[/TD]
[TD="class: rt_leaf"]Pressure Regulator Valve Inner Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](313)[/TD]
[TD="class: rt_leaf"]Pressure Regulator Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](314d)[/TD]
[TD="class: rt_leaf"]1-2, 3-4 Shift Solenoid Valve Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](314e)[/TD]
[TD="class: rt_leaf"]Pressure Control Solenoid Valve Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](314f)[/TD]
[TD="class: rt_leaf"]TCC PWM Solenoid Valve Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](314g)[/TD]
[TD="class: rt_leaf"]TCC Regulator Apply Valve Bore Plug Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](315a)[/TD]
[TD="class: rt_leaf"]1-2, 3-4 Shift Solenoid Valve Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](316a)[/TD]
[TD="class: rt_leaf"]1-2, 3-4 Shift Solenoid Valve O-Ring Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](316b)[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](317)[/TD]
[TD="class: rt_leaf"]1-2 Shift Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](318)[/TD]
[TD="class: rt_leaf"]1-2 Shift Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](320)[/TD]
[TD="class: rt_leaf"]Torque Signal Regulator Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](321)[/TD]
[TD="class: rt_leaf"]Torque Signal Regulator Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](322)[/TD]
[TD="class: rt_leaf"]Pressure Control Solenoid Valve Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](323)[/TD]
[TD="class: rt_leaf"]Line Pressure Relief Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](324)[/TD]
[TD="class: rt_leaf"]Line Pressure Relief Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](325)[/TD]
[TD="class: rt_leaf"]Line Pressure Relief Valve Spring Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](326)[/TD]
[TD="class: rt_leaf"]TCC Regulator Apply Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](327)[/TD]
[TD="class: rt_leaf"]TCC Regulator Apply Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](328)[/TD]
[TD="class: rt_leaf"]TCC Regulator Apply Valve Bore Plug O-Ring Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](329)[/TD]
[TD="class: rt_leaf"]TCC Regulator Apply Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](334)[/TD]
[TD="class: rt_leaf"]TCC PWM Solenoid Valve Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](335)[/TD]
[TD="class: rt_leaf"]TCC Control Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](336)[/TD]
[TD="class: rt_leaf"]TCC Control Valve Spring[/TD]
[/TR]
[/TABLE]
Control Valve Body Assembly (2 Of 2)
[TR]
[TD="class: rt_leaf"]Machined Control Valve Body[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](314a)[/TD]
[TD="class: rt_leaf"]1-2 Accumulator Valve Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](314b)[/TD]
[TD="class: rt_leaf"]4-3 Manual Downshift Valve Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](314c)[/TD]
[TD="class: rt_leaf"]2-3 Shift Solenoid Valve Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](315b)[/TD]
[TD="class: rt_leaf"]2-3 Shift Solenoid Valve Assembly[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](316)[/TD]
[TD="class: rt_leaf"]O-Ring Seal[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](339)[/TD]
[TD="class: rt_leaf"]1-2 Accumulator Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](340)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](341)[/TD]
[TD="class: rt_leaf"]3-4 Accumulator Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](342)[/TD]
[TD="class: rt_leaf"]2-3 Accumulator Valve Bore Plug Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](343)[/TD]
[TD="class: rt_leaf"]2-3 Accumulator Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](344)[/TD]
[TD="class: rt_leaf"]2-3 Accumulator Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](345)[/TD]
[TD="class: rt_leaf"]2-3 Accumulator Valve Bushing[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](346)[/TD]
[TD="class: rt_leaf"]2-3 Accumulator Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](350)[/TD]
[TD="class: rt_leaf"]1-2 Accumulator Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](351)[/TD]
[TD="class: rt_leaf"]1-2 Accumulator Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](353)[/TD]
[TD="class: rt_leaf"]3-2 Manual Downshift Valve Retainer[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](354)[/TD]
[TD="class: rt_leaf"]3-2 Manual Downshift Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](355)[/TD]
[TD="class: rt_leaf"]3-2 Manual Downshift Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](356)[/TD]
[TD="class: rt_leaf"]3-2 Manual Downshift Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](357)[/TD]
[TD="class: rt_leaf"]2-3 Shift Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](359)[/TD]
[TD="class: rt_leaf"]4-3 Manual Downshift Valve Bore Plug[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](360)[/TD]
[TD="class: rt_leaf"]4-3 Manual Downshift Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](361)[/TD]
[TD="class: rt_leaf"]4-3 Manual Downshift Valve Spring[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](362)[/TD]
[TD="class: rt_leaf"]3-4 Shift Valve[/TD]
[/TR]
[TR]
[TD="class: rt_leaf"](385)[/TD]
[TD="class: rt_leaf"]2-3 Accumulator Valve Bushing Assembly Retainer
[/TD]
[/TR]
[/TABLE]
[h=1]Fastener Tightening Specifications[/h]
Description of Usage
Metric
| English
2-1 Servo to Case
| 25 N·m
| 18 lb ft
Accumulator Cover to Case
| 12 N·m
| 106 lb in
Case Cover to Case
| 12 N·m
| 106 lb in
Case Cover to Case
| 12 N·m
| 106 lb in
Case Cover to Driven Sprocket Support
| 25 N·m
| 18 lb ft
Case Cover to Driven Sprocket Support (TORX®)
| 12 N·m
| 106 lb in
Case to Drive Sprocket Support
| 25 N·m
| 18 lb ft
Case Extension to Case
| 36 N·m
| 26 lb ft
Case Side Cover to Case
| 25 N·m
| 18 lb ft
Case Side Cover to Case (Stud)
| 25 N·m
| 18 lb ft
Case Side Cover to Case (TORX® Special)
| 25 N·m
| 18 lb ft
Detent Spring to Case Cover
| 12 N·m
| 106 lb in
Forward Band Servo Cover to Case
| 12 N·m
| 106 lb in
Manual Shaft/Detent Nut
| 32 N·m
| 23 lb ft
Oil Cooler Quick Connector
| 38 N·m
| 28 lb ft
Oil Cooler Quick Connector with Checkball
| 38 N·m
| 28 lb ft
Oil Pan to Case
| 14 N·m
| 10 lb ft
Oil Pressure Test Hole Plug
| 12 N·m
| 106 lb in
Pump Body to Case
| 16 N·m
| 11 lb ft
Pump Cover to Case Cover
| 12 N·m
| 106 lb in
Pump Cover to Pump Body
| 8 N·m
| 70 lb in
Speed Sensor to Case
| 12 N·m
| 106 lb in
TFP Switch to Case
| 16 N·m
| 11 lb ft
TFP Switch to Case Cover
| 12 N·m
| 106 lb in
TFP Switch to Valve Body
| 8 N·m
| 70 lb in
Valve Body to Case
| 12 N·m
| 106 lb in
Valve Body to Case
| 12 N·m
| 106 lb in
Valve Body to Case Cover
| 12 N·m
| 106 lb in
| 12 N·m
| 106 lb in
Valve Body to Case Cover (TORX®)
| 12 N·m
| 106 lb in
Valve Body to Driven Sprocket Support
| 25 N·m
| 18 lb ft
[TH="colspan: 2"]
Specification
[/TH]
