Mark_PontGTP
Adding Power seat on the passenger side
Power unit from the drivers side
This is the reat section beside the console
A hole needs to be drilled to change the offset from the drivers side to passenger
This is the front outer section drill new hole for offset
This is the front iner section drill new hole for offset
Make angle iron for offset of the reat outer section
Had to open up the front inner of the seat frame
And here is the seat all bolted up
And now the side plastic for the switches
Made a template from the other side and cut out the plastic for the power seat switches
Used epoxy to glue the switches in and yes the controles will work normaly
if you want the re wriring instuctions let me know
Here is the finished seat with the side
ORIGINAL WIRING:
BEIGE = FORWARD
GREEN = BACKWARD
GREY = RAISE FRONT
WHITE = LOSER FRONT
PINK = RAISE REAR
VIOLET = LOWER REAR
MOVE THE FOLLOWING:
BEIGE TO GREEN AND GREEN TO BEIGE
GREY TO PINK AND PINK TO GREY
WHITE TO VIOLET AND VILET TO WHITE
INSERT A SMALL FLAT SCREWDRIVER WHERE YOU SEE THE U SHAPE
TO UNLOCK THE PINS YOU CAN SEE THE TAB IN THE PHOTO
FOR THE LUMBAR I DINT CHANGE ANYTHING
GOOD LUCK
ORIGINAL WIRING:
BEIGE = FORWARD
GREEN = BACKWARD
GREY = RAISE FRONT
WHITE = LOSER FRONT
PINK = RAISE REAR
VIOLET = LOWER REAR
MOVE THE FOLLOWING:
GOOD LUCK
