Power Passenger Seat conversion
Mark_PontGTP
Adding Power seat on the passenger side
Power unit from the drivers side
This is the reat section beside the console
A hole needs to be drilled to change the offset from the drivers side to passenger
This is the front outer section drill new hole for offset
This is the front iner section drill new hole for offset
Make angle iron for offset of the reat outer section
Had to open up the front inner of the seat frame
And here is the seat all bolted up
And now the side plastic for the switches
Made a template from the other side and cut out the plastic for the power seat switches
Used epoxy to glue the switches in and yes the controles will work normaly
if you want the re wriring instuctions let me know
Here is the finished seat with the side
ORIGINAL WIRING:
BEIGE = FORWARD
GREEN = BACKWARD
GREY = RAISE FRONT
WHITE = LOSER FRONT
PINK = RAISE REAR
VIOLET = LOWER REAR
MOVE THE FOLLOWING:
BEIGE TO GREEN AND GREEN TO BEIGE
GREY TO PINK AND PINK TO GREY
WHITE TO VIOLET AND VILET TO WHITE
INSERT A SMALL FLAT SCREWDRIVER WHERE YOU SEE THE U SHAPE
TO UNLOCK THE PINS YOU CAN SEE THE TAB IN THE PHOTO
FOR THE LUMBAR I DINT CHANGE ANYTHING
GOOD LUCK
Hey I know this was a longg time ago and you might not even be on here anymore BUT I was wondering if you still had the pictures from this cause there not on here for whatever reason and I'd love to do this.. Thanks!
Hey guys yes this was a long time ago and since I no longer own GPs had 4 of them over the years
but I did come across the pics for this conversion
if you send me your email I will send you the pics
Mark
Mark
Hey Mark did you ever send those pictures? I PM'ed you my email but never got anything. If you don't have them it's cool I just wanted to do this during summer. Thanks!
If you get a copy of them please post them up, I've been wanting to do this to my Passenger GXP seat. I'll probably buy everything next JY trip so I might just try to figure it out without the pics...and I'll take pics along the way, lol.
I found the pics
I will send them out this weekend
sorry guys but im not on here to much anymore since I no longer have a GP
K guys, I have the pics, please remember. I have not done this yet. I will be doing it with a 04+ seat eventually, so I will be able to answer the questions then. I also have higher res pics, but these have captions.
The pictures were number 1-15 so thats how I posted them, I hope the line up with the OP's write up.
