Post Whoring Thread 2.0- DON'T DELETE THIS ONE
Status
Not open for further replies.
I have been thinking about three glass packs. One 2.5 x 30" for a resonator then a couple 2 x18"ers where the muffs were. And the split tips off a 40th GTP. I bet that would be fairly quiet.
I don't feel like spamming pics so here is the album http://imgur.com/a/IpRoK#2 but, anyone see anything wrong in these pics besides the crack on the sway bar link thing? Wetness is from car wash previously.
you need new lca's, new sway bar end links, and maybe a new sway cant tell for sure if its cracked in this pick or not. bottom of the bar inside of the end link.
Oh rats I thought i might need lcas because the one thats wet doesn't look right. Might that cause the car to wander on the highway, or me to feel a kinda "clunk" or something shifting in the steering while turning left like curving on an onramp? Also my sway bar creeks bad somedays or when going up into a parkin lot on an angle that's steep wouldn't surprise me if its breaking.
the main sway bar bushing can creak. the lca's are new ball joints as well so it could make it wander, (and they clunk) but so could tie rods.
jack each front tire up, one at a time, lugs tight, push and pull at the 3 and 9 o clock areas of the tire, you'll feel it clunk if the tie rod is bad. if you look at it you can also see if it moves.
did that earlier today, no movement or clunk that I heard. I can feel in the wheel its hard to explain like something is loose then hits one side and you can feel the impact but only when going like around a roundabout or onramp when the car has more momentum and sometimes corners but it doesn't happen everytime around corners. I can't think of how to describe it lol.
well your bushing dont look good on the lca and the ball joint may as well be shot too.
So I guess it's daylight savings today. Luckily I live in a province that never changes time lol
Sent from my SGH-I337M using Tapatalk
Holy crap...my car does the EXACT same thing! Let me know if the new LCAs fix it...
Status
