acidcrashdburnd
Everything is rolling along great in the GT but last night I wanted to connected to BCS wire into the PCM harness. I did this and the thing still doesn't work. I will assume its the ZZP computer and it may not be programmed to have the BCS, but any other options/opinions would be appreciated. I can tell you the PCM is programmed to use a GT map and not a GTP so I wont be able to read boost electronically, not sure if that has anything to do with it. I have the pigtail for the BARO sensor and the sensor but I see no point in wiring it in as I doubt ZZP put the option in the PCM as well. I'm stuck any ideas? I was going to take the BCS off of my moms 2001 gen3 as I know it is good and connect it to my car and see if their is any change. But as of now when the car is at idle the valve is half closed and doesn't change at any speed/rpm.
