Performance Shift
Yes.
But its already "built into" the pcm on 01+ cars that dont have the button.
I think there is a thread that shows you what you can do to put on in.
You need a re-programmed PCM with the correct Cal's for performance shift.
You also need to run a wire from the ECU, through the shifter switch, to ground.
Pin 21 Clear connector.
Seems like forever ago that I figured out how to do this... heh
The writeup from my old website:
RivMan's Page
-Rob
