blowfishRus6
it will be like an unexpected christmas
Paid night of nov 23 and first delivery attempt was made dec 2.
Works great, little unsure of the shift point (6100?). Other than the communication issue it seems to be going just fine.
Question: If the DIC is flashing zero on every mode, is it because the PCM is learning or because I didn't hook it up properly?
Why are you unsure about the shift point 6100? I believe he programs them for 6000-6100rpm 1-2 and 5900-6000 2-3. If you think that is too high he can command the 1-2 shift earlier or someone with a tuner can since his pcm's are unlocked now.
Yeah, I don't really have any issue with it being around there, the tach makes it seem a bit higher.
BIG problem...it means the PCM is still in Program mode, I'd contact will asap.
oh ok, so do you think ill be able to order an 05 and get such a good turn around or i don't know not get the same service. . . . (i guess my question is should i take a chance and order one given the whole not answering emails situation)
will the car crank???
i would not run it tho and send it back.
You can easily find solution for your problems on google search or on several websites.
