overkill pcm
^^^^mine too. First e-mail took a couple of days but after that no problems and agreat product. Try to pm him on G P O N A
Paid night of nov 23 and first delivery attempt was made dec 2.
Works great, little unsure of the shift point (6100?). Other than the communication issue it seems to be going just fine.
Question: If the DIC is flashing zero on every mode, is it because the PCM is learning or because I didn't hook it up properly?
Why are you unsure about the shift point 6100? I believe he programs them for 6000-6100rpm 1-2 and 5900-6000 2-3. If you think that is too high he can command the 1-2 shift earlier or someone with a tuner can since his pcm's are unlocked now.
Yeah, I don't really have any issue with it being around there, the tach makes it seem a bit higher.
If it is higher than 6100 then their is a delay between shift command and the actual shift. This happens more with higher milage trannys. Its probably fine, it bothered me at first because I was so use to the stock shift points but you will get use to it and like it. Shift kit will help too.
so ur saying u paid for a pcm on the 23 of this november and recieved it yesterday. . . . quick question. for what model year did you purchase????
oh ok, so do you think ill be able to order an 05 and get such a good turn around or i don't know not get the same service. . . . (i guess my question is should i take a chance and order one given the whole not answering emails situation)
your car should take no longer to tune than any other car. hes been doing it for while so im sure he can pop them out pretty quick. then you just have to wait for it to get shiped across the border.
Hi every one.
I don't like to stick my nose in other peoples buisness.
I know Will well and will pass this info onto him so he can respond to the questions at hand.
Overkill get swamped with P.M's and reply's from all over, and i know i would hate to be the one to open his E-Mails :)
I hope this helps you all out.
Happy new year to you all
