231FUN
Scotty, PCV system is blocked off on these cars.Turbo cars require the breather or an air pump. You cannot have a PCV system with the inlet after the turbo because the turbo will pressurize your crankcase and destroy seals, so the breather becomes the inlet.dont know if the turbo caused the blow by, but when that happens the oil ring on the piston is dead in a N/A engine.
i had this in a old car, the dip stick was getting blown out of the tube, and spitting oil up the tube as well. the pcv tube was also full of oil.
