lmao You read my mind, just not the 10W-40 part. 10W40 = :th_skull: in WI But then again pure syn might be ok in that weight
10w-40 is too thick for newer engines. The celerances are too tight.
...we keep the better Frams...
Oxymoron...Fram is junk no matter which version you choose.
True, I can confirm that. I have extrapolated my OLM a few times and it always puts me at ~9k mile oil changes. My personal worry is that I don’t see many oils that advertize 10k oil changes.But at the same time I do know GM fully stands by their OLM. Even thought they use a fairly robust algorithm for the OLM, it can’t compensate for all the variables.:th_computerproblem:
K&N It's a white Mobil 1 filter with a nut welded to the back. It's made by Champion Labs using what I call their "performance" design instead of the "Ecore". Save the $2-$3 plus shipping and get the Mobil 1.
On my GP, I used RP 10W-30 with Pure One filters.
To the people running extended oil change intervals, I'd highly recommend using a synthetic/fleece filter. Several German car owners with extended oil change intervals (over 10,000 mi) have seen the paper filters disintegrate. I don't know if anybody here plans on going that long, but I've seen some people on other GP forums who get oil analysis going 15-20k mi between oil changes.
Here's a pretty informative site describing most filters on the market:
Oil Filters Revealed - MiniMopar Resources
A lot of the more expensive "high end" filters are made by the same companies using the same materials as less expensive filters. For example, here's what they have to say about the K&N filters:
