Noob mistake now I'm lost
the factory one runs around the front of the engine, then over the intake and to the alt. I believe it also connects to the wire that runs to the starter and other things down there, so fixing it eventually is a good idea.
To get it running now, the fused link from the alt to box is good enough.
Thats the only power wire to the starter, direct from battery
Untitled by Corey S, on Flickr
I guess I'm just confused as to how this prevents the car from starting? I mean it is what it is and maybe I shouldn't question so much but maybe once I have the knowledge I can help someone in the future.
Sent from my Z963VL using Tapatalk
Its connected to other things which makes it a complete circuit.
try the alt to box link first, then if that doesn't work...
I would suggest starting at the alt, and work your way towards the battery.
Should I take the factory red fusable link wire off from the box too or just disconnect it from the alt? I suppose I was just going to cut and tape the end at the alt and cut and tape the end at the box.
Ok. Digging into the harness sounds fun haha good thing the car goes into storage for the winter I can dig into it then. I just need it to run from now till late October.
I'll have to research that this winter, but goal numbe 1 is to get my running car back haha. My wife uses the 04 and I haven't yet bought this year's winter beater haha. Wish me luck tomorrow, I'm going to bed with fingers crossed.
Maybe Even a video if for some reason this doesn't make her run
Well here's what I got made, we pooled solder in the terminals and crimped them. Didn't have big enough shrink tubes so I'll have to go buy some in a little bit. Gotta get brakes done on the 04 first today then I can get this on an pray.
It didn't work guys still just cranks but no pop. I'm thinking the injectors are no getting a signal to pulse
take your head light out and remove the marker bulb, un clip a injector and put the bulb in the injector plug, crank the engine engine watch for the bulb to flash. if its flashes its working, no flash, they are not firing.
