Hold on a D^MM minute. Sell a Vette??????? Oh hell no. But start the project anyway. Foxbody mustangs are bada$$. IMO. I even have a Black w/ charcoal gray int. 87 GT 5.0 5spd Convertible. Still factory except for the sub-frame connectors and mass-air swapped in, instead of the speed-density. I can help with that as well. Very simple swap to add Mass-air. Computer, Mass-air meter and add two wires to the wiring harness. I will even send you the wires for the harness. They just plug right in.
ENjoy.
best fox body ive seen had a turbo ls1 with the t56 6-speed in it.
f-body rustang? ugliest car on the road. i say keep the vette and the s10... 383 stroked s-10.
Foxbody ftw.
I miss mine :/
All motor was running low 12's on street tires.
You me talk now, what has to be done for this build? I know the shive ass rear-end in it now has to be taken out what would be better an 8.8 or a 9"? What about the suspension what has to be done? And basically what should I be watching out for in this build?
I had a 8:8 posi rear, eibach full suspension, you definitely want to re-enforce the sub frame, 4.10 Gears, super high grip tires, if you're super serious about it, get rid of the T-5 Tranny, throw a Tremmec in there, that's what I had after 2 T-5's.
Make sure the car isn't rusted out, especially under the floor boards, they go first most of the time.
As far as motor work goes, I had a 302 bored over, AFR heads, E-303 Cam, BBK Shorty Headers, Holley 750 DP Mechanical carb, forged crank, pistons, bbk intake manifold, full exhaust, aluminum drive shaft, fiberglass hood, and a bunch of other crap I can't think of.
It was a fun car.
The trans will either be a TH350 or a 2speed, no ford trans here or ford motors. What should I be looking at for suspension with it coming from a 4cyl like should I be getting a full suspension upgrade or just the front? Where did you get that drive shaft I can't find them and I need it modified for my setup it will be to long or to short lol
X2. FULL suspension. I love the F-body style. The 9" rear would be better, however I've never seen an 8.8 break. I'm sure they have though. Anything mechanical can and will break with enough power...
