Today I was doing a new LIM. All was going well until I had a probelm with one of the injectors. I was pulling number 6 out in the pack drivers side. It popped out harder than I wanted and I noticed that the rim around the bottom just below the o-ring was broken. It had a piece missing out of it. I sure that this happened when I pulled it out.
I was concerned that it fell into the injector hole in the head. I looked the best I could but that thing could be any where. It could have fallen in the hole it went some place else. I took a shop vac with a small end on it made of 3/4 inch copper and put it on the injector hole hoping to vac it out. I have no idea if it did.
Next I had to put an injector that I had on the shelf from another motor. I believe that it is a stock injector. Dummy me, I put it in the same hole that the one broke in. When I got the car started it wwas running rough and I got an immediate flashing check engine light so I shut it down.
I put my actron on it and it said misfire in 6 which is where the injector was that came from the shelf. So that didn't tell me if it was the injector or the piece. So I took another injector off the shelf and put it in #3 up front and put the #3 injector in the back in #6. I left the old code without erasing it and started the car. It was still running rough and I got the code multiple misfires. Well that had me confused so I decided to erase the code and see what it would say.
I erased the code and started the car. No check engine but it was running rough so I knew it would throw a code so I shut it off. I scanned it and got a pending code P0202 "injector circuit open - cylinder 2".
What have I done? Can anyone help please?
