Need some help on rebuild
I torqued them to the recommended torque specs when I had the engine on the stand. I'm using the felpro intake manifold gaskets also.
Sent from my SGH-T989 using Tapatalk 2
Oh no, this sounds allll to familiar! When you torqued the Cam, did you re-use the same bolt? If so, did you clean/thread lock it good?
I hate to say, I had this EXACT same sound then no start, came to find out the cam bolt backed it self out and now I'm on motor #2 :(
Take off the front cover and inspect your cam bolt and keyway, if you see any damage there, I feel your pain man lol.
No I used a brand new cam bolt from zzp.
I torqued the cam bolt on tight in an engine stand so there's no way it could have backed out and un screwed itself.
^^^^ So very correct.
The bolt I think is 75lbs plus 90*. You know why it is plus 90* because most engine builders don't have torque wrenches that go to that high.
I torqued the cam bolt on tight in an engine stand so there's no way it could have backed out and unscrewed itself.
This happened to one of our bonneville guys 95Nasta.(crazy engine build too not just a rebuild). I would pull the timing cover.
So I just self F it and went and bought a head gasket from auto zone and took the front head off to inspect. Check the entire head and everything seemed fine and the pistons also. I put the head back on and torques and soaked the lifters and added oil in the valleys this time.
When I went to tighten down the rockers...it seemed as though this time the springs actually compressed lower this time than before and not all are depressed at the same time
I need new lin gaskets and ive been busy with work so ill finish tommorow or Saturday.
Also the rockers before had play which I think was causing the tapping but this time NONE has play.
Yea I'm reusing them but need new side tabs cuz the old ones got destroyed when I pulled them off.
Smh went and for some new lin gaskets and finished putting everything together and the car started with the same valve chatter so I turned it off and tried to start the car again but wouldn't start again Smh
