Need HID help, with pics
rocafella2032
i understand all this, but where do those two metal connectors go?
these are for projectors by the way, im using stock harness
I just cut the ends off and slid them thru the rubber grommet. I ended up making my own harness out of a heavier gauge wire then what came with the projectors with that I put in a 9006 connector so I didn't have to "connect" to the projector harness.
In regards to your diagram...
This is going to be hard to explain... The 2 wires on the projector harness that go to the H1 (low beam), connect those two wires to the wire ends you have circled. Then the 9006 connector (the other one you have circled) goes to the ballast.
The two connectors on the top right that go the HID bulb plug into the similar connectors coming from the ballast. The ballast should be connected to the factory headlight connector. The plug on the top left with the two wires that are circled could probably be used for the high beams on the projectors. The two wires circled can be tapped into the high beam wire and ground wire from the factory wiring. Do you have pics of the ballast just to be sure.
A pic of the ballast would help. But the 9007 plug should fit into the ballast connector. Nevermind I forgot we have that big blue connector. I have mine on a relay harness so its different from your set up.
PLUG THOSE TO THE 2 WIRES THAT GO TO THE ORIGINAL BULB IN THE PROJECTOR they are blue and black and come from the harness for the projectors
when you remove the rubber cap on the back of the projectors there are two wires going through that cap, plug your two wires that are lost into those they do not fit perfectly size wize as one of male connectors is smaller but just pinch the female connectors tight before puttin in the male connectors.
the original wires to the old halogen bulb are now the power source for the ballasts....wires that come off the original halogen bulb in the projector go to those connectors....
