1. Apply protective coating/tape at the rear of the rear door power window switch (right and/or left door).
2. Remove the rear door power window switch from the rear door trim panel using a small, flat-bladed tool, inserted at the rear of the rear door power window switch plastic mounting plate. Press forward in order to release the rear door power window switch mounting plate.
3. With the rear retainer released, pull the switch to the rear and lift up to remove the mounting plate and switch.
That is all I can find. I am pretty sure the front come out the same.
