wowitsfast
Ok so I put in a new o2 sensor. Bent the tab out like scotty said to. rechecked the vac lines. I did find some more of the charcoal plugging the evap canister purge valve. the short line to the evap vac switch was plugged to the point I couldnt blow it through and the valve was plugged but none in the line that returns to the TB. I unplugged the battery for 30 mins then started the car. it idled good for about 5 mins annnden.
https://www.youtube.com/watch?v=ugbflpPMDYY&feature=youtu.be
the MIL code see is a P0135 and i just changed the o2. Is it possible since my car has a cat delete some one extended the pre cat o2 to be the post cat o2 they way the wiring looks it might have happened. so if i put a post cat o2 in a pre cat connection would it through a code? im lost again
