N* install and plug question
I swapped to autolites 104's 50 gap and zzp plug wires and im getting a nasty miss and it dies after a few sec
Plugs and wires thats all. like i said they are 104's gapped at 50, could it be caused if i didnt screw one of the plugs in all the way? Faulty plug?
why did you ask which plugs to use in your NA and then use a two range colder and gapped smaller plug for an SC motor?
Why are you asking which adapter you need to make the N* work on your NA? Either put on the topswap or leave it off. There is no gain to be had by swapping it onto the L36.
But i might be interested in using a N* for my csc build using the l36 uim
