Re: My project bike: 1994 CBR1000F
once i get it running well ill definitely take a video, but for now...
a little update:
got everything torn down and the bike it completely stripped at this point. figured out why there was no gas in the cylinders: all the jets were clogged and 3 out of 4 floats were stuck. this bike sat for a long time and i could tell. here are a few pictures:
i also started doing a little painting work while i was waiting for the jets to get cleaned while they were soaking in carb spray:
that gloss red is going to look awesome up against some flat black.
so once the carbs were reassembled (with the new jet kit i put in) i put them back on the bike and left the air box off. i think im going to just stick some cone filters on them and run the bike pretty much as is. i put the tank back on and the bike started (after a bunch of hard cranking and playing with the idle set screw). guess what? vacuum leak city. the idle isnt steady and it doesnt run unless i have the choke on. i decided to take it around the block to see what else is wrong with it so i can fix it all at once and put it on the road fixed and awesome within the next month or so. this is what i found out:
- forks are bent...should have known. i can still ride it, but the handlebars arent straight and it just feels funny to have to turn. i havent decided if i want to swap in a new set of forks or if i want to try and bend mine back yet...
- back brakes just straight up dont work, ill have to check the fluid level and too see if the pedal is even connected correctly.
- the chain is loose as a goose, so ill have to try and pull the tire back and snug it up for now, but a new chain is pretty much needed at this point.
after all that i can say that it runs and drives. the cooling system works, there is oil in the motor that is fine, the exhaust isnt all full of holes or anything and sounds good, and the transmission shifts smoothly through all 6 gears. once i address the vacuum leak in the intake boots ill be able to tackle the rest of the problems and then this bike is as good as its gonna get. it seems to pull hard and the engine makes no funny noises. the intake is pretty loud with no air box, you can see and hear them chattering which is kind of cool when you rev it and hear it gulping in air like that.
overall, decent purchase, but by the time im done fixing problems it will have about as much money into it as it would have been if i'd have bought it in running condition. either way, i love the bike in general so hopefully everything works out well.
