I may add a double roller and ported heads, but this is what i have so far
L67 block and rods
L36 trans
Vs camshaft
Federal mogul hypereutectic pistons
Hastings piston rings
Rod bolts
Camshaft bearing
Rod bearing
Main bearing
Ls7 lifters
7.05 pushrods
90lb valve springs
Ported throttle body
Ported supercharger
3.4 pulley
Cold air intake
Headers
Alternator voltage booster
Tuned pcm
Shift kit
New gaskets all around
Lowering kit with new struts
Oil pump and volume kit
L67 block and rods
L36 trans
Vs camshaft
Rod bolts
Camshaft bearing
Rod bearing
Main bearing
Ls7 lifters
7.05 pushrods
90lb valve springs
Ported supercharger
3.4 pulley
Cold air intake
Headers
Tuned pcm
Shift kit
