My 04 gp projector retro... Finished!!
Re: my 04 gp projector retro... so far
Take a dremel and carefully cut the JB weld off and hopefully you can remove or adjust the projector without breaking the reflector.
That's the exact reason why I just use a little bit of quick steel or JB putty to hold it. Aim it, leave the car exactly in the same place until the putty dries so if you have to adjust them make you can do it before it completely dries. Then it should be on sturdy enough where you can remove the the headlights, the the reflector then use either more putty or JB weld to reinforce it even more. Should be a awesome even cutoff if you do it right.
Here a shot... i will have to get the cutoff shot later
Thanks... im just not sure about the cutoff... im pretty sure its messed up lol
You can adjust the passenger higher too..there's a little screw on the top of the headlight for a Philips screwdriver. Turn the lights on at night n twist left or right, whichever way makes it go higher n you're good to go. They are straight and not crooked like mine a little.
Not the best pic, but above the dremel at the top of where I cut out is where it's at. Pop your hood n there's the silver screw, n that's for adjusting n aiming height, up or down.
Oh ok damn i was getting worried that they were really messed up lol... oh ya i forgot about the height adjustment screw! Lol i will go out and adjust it up a little more... thanks everyone for the input... i def like the output though it is wayyy better then stock( and also the HIDs i had in there before lol) its like seeing the road for the first time lol
You mean the driver side can come up a bit. You can see the step / for the passenger side is higher. Personally it looks fine as is unless your bothered by it
Ya i knew what he meant lol i am going to adjust the driver side up a little bit
Lol yeah, my baaaad redcompg haha. I never knew about the adjusters even during or after my retrofit, then one day I was like wth is this n found out haha. Lifesaver
No problem I'm here to call u out when your wrong lol.
Wow you guys never noticed the adjuster lmao someone needs to take a peak at the owners manuals
They really don't seem that crooked to me. Not sure if 04+ cars have them but can you adjust them sideways? The steps seem to be too close together. I've tried to attach a file that is on TRS website that helped me when I was in the aiming process.
So got some more pics today, wired up the red inside halo to a switch so i can turn it on and off.. also i hooked up the white halos to my drl's so the come on automatically... and also use them as a turn signal
Hers a video of the halo as turn signals
[video]http://s128.photobucket.com/user/Alix0r/media/VID_20131101_141626_290.mp4.html[/video]
