Tuner-Extraordinaire
no iridium.
Going back to the original post, here are the big items to look at.
- Spark plugs – if you are running on the stock plugs (and you probably are) it is time to change them. IMHO the best plug for you is the NGK OE laser iridium or the NGK iridium IX, the best part is once you change them you should never have to bother with them again.
- Front oxygen sensor-if your car has over 120k replace it. This is the most important fuel related sensor in your car. A slow/old O2 sensor can destroy your fuel economy.
- Don’t idle your car if at all possible. "Warming" your car up, drive-thrus, any idling eats up gas unnecessary. Just remember idling = zero mpg
- Proper tire pressure = the very minimum pressure you should ever run is 30psi, and even then only for track day. IMHO the best pressure to run for improved handling and mpg is ~33-35psi.
- Dead weight-get rid of anything in your car you don’t expect to use that day. And if you feel lucky that could mean your spare tire.
- Drive smooth and roughly the speed limit, use cruise when ever practicable, use the A/C when you need to otherwise crack a window.
Correct me if im wrong put putting more air into the engine will not get you better fuel mileage. The more air that gets in the more fuel you use.
This is all theory here, but IMO anything other than a u-bend delete wont help gas mileage that much. When you are cruising you are not giving off a lot of exhaust gas so the restrictions arent as big of a deal. I dont think you would ever make the money back in gas savings by buying headers.
Lose weight in the car, accelerate very slowly, dont use cruise control on hills, use the lowest AC setting you can or open windows, get an alt rewire and voltage booster. You could do the "Big 3" If you really wanted, dont know how much it helps. Proper tire pressure will probably help the most, and make sure your wheels are aligned.
Also, not sure if you have a supercharger or not, but if you do you could get a 4" Pulley if you dont care how fast it is.
You're wrong.
You are getting more air to the engine, but you have made the intake more effeceint because you need less throttle to acheive the same increase in speed, relative to a stock intake.
no temptation to speed up.
And my last words of wisdom are to remember GM spent money to put the pieces on your car like intake manifold runners and spare tires, so think long and hard before removing them.:th_nervous: lol
So you use less throttle to get the same amount of air, hence using the same amount of gas?
