EmEaston24
can i get a dhp pcm without raised shift points? i plan on putting rockers in but i dont know the ratio... and i hear as long as i dont go past 6k ill be fine without springs.
DHP's shift at 6K...it is ZZP/Intense that raised theirs to 6200 or something IIRC.
By the way...it would be very smart to know what parts your putting on your car before you go through with it...because if they are 1.9's then you are going to need upgraded valve springs/retainers or your going to get valve float. 1.84's are the highest you can go on stock springs...and keep it mind it still won't totally save you...I was shifting at 6200 and I wouldn't be one bit surprised it floated a bit in the top of 1st and 2nd.
