I have a few questions and some advise needed!
2005 Grand Prix GT 117k Miles
Bought the car with 113k Miles
So far I've done
All new Rotors
All new Brakes
Oil Change done twice so far "Valvoline"
New AC Delco Wires/Plugs 41-101
PCV Valve
Radiator Flush
Plastic Elbows "which caused all new fluid to come out"...
Back Drivers side wheel hub bearing.
Next I want to do a transmission change which means I just want to drop the pan, drain, put new filter, fill with new fluid. I know it should be done every 100k so would I still be okay? I read thread on here and it kinda freaks me the "F" out =/
My Serpentine Belt looks fine and not sure if that was ever replaced so should I go ahead and replace it anyways?
Also how do you check if your suspension is bad? When I drive the car I can feel vibration from the steering wheel which isn't to bad until I drive on the express way and then you can really notice the vibration. I'm not really sure what to look for if something is bad or broken.
Anything else that i should know of or do to help make my vehicle have a long wonderful life?
Thanks! =D
So far I've done
All new Rotors
All new Brakes
PCV Valve
Radiator Flush
Thanks! =D
