Typically, I had an XP, Headers, with a ported GenIII blower, 3.4", stock TB, DHP PCM with the P0300 code removed and the shift points turned up (stock timing mind you)...stock transmission...stock heads...crappy 225 Bridgestones...and it went consistant low 13's on pump 93 as well with traps always around 103-105. Never dynoed. It ran with mid 12 cars on the street...it never has been a track car...I always break something.
Since then...Thrasher Race Cam, custom heads, stout valvetrain, Triple Edge Transmission, fully done GenIII, 42.5lb. injectors, 3.1", custom tuning via HPT running 20-22* WOT...with no knock (even during 30* or colder weather...since you tune you know how much of a difference it makes at such high mod levels)...and tons of other small bables and bullsh1t.
Getting dyno'd if I go to the Ohio Meet. Or, waiting for this fall when they have another local dyno day since they are uber cheap.
Furthermore, guy...I've got nothing to really prove to you. You've got all these plans to run a LSJ M62...then you want to run a TVS...and money isn't an issue.
Good luck with your build.
