I switched over to supermotors.net as my photo hosting site. I will gradually fix the other photos that photobucket “stole” from me. I already fixed the photos from my last 2 posts.
Did some work on the car last night. Mostly messy stuff. Dealing with the wire wheel and rust dust and OSPHO dripping down from everywhere. No Bueno. The biggest bummer was that I could not finish drilling out that tie-rod end from the knuckle. See previous post, (Post #165). The drill bit stopped catching after a little bit. The smaller hole I had already drilled was slightly off center, so this bigger hole I attempted to drill is somewhat oblong. Meaning I messed up on the drilling and might have caught some of the actual knuckle. No problem I thought..., I can smooth it out and make it more circular with some JB-Weld. But I still cant get that piece out and it looks like the two metals fused together from the heat. What to do, What to do? Do I need a different drill bit like an extractor bit? There’s also the possibility that I have the wrong knuckle on the drivers side anyway, as the caliper bolt hole sizes are different. See measurements below.
Hit the new trailing arm brackets with a coat of Rustoleum for extra protection. Rear sway-bar brackets also got a coat:
Before I cleaned with the wire wheel...this is passenger side, but both sides looked like this:
Cleaned up:
Cleaned up and dripping with OSPHO:
Getting ready to drill this b1tch out!
And....Nothing. Sucks. Not sure what to do here. Drill bit will not catch on the metal just spins round and round no matter what. Use a file to file it out?! But that would take forever!
Washers/spacers(or washer nuts) aren't used for the bracket bolts.
I wonder why some slickmeister put them there.
I think some slickmeister put them there because that’s the wrong knuckle all together. Since the metal isn’t fat enough where the bolts pass through, without the those metal spacers/washers these mounting bolts probably rub the rotor. Again, see photos in Post #165. Should I just get the correct knuckle given the tie–rod problem and the fact that using spacers/washers at the brakes isn’t very safe? Not looking forward to the work involved at the axle, but maybe that’s what I should do, get a used (new) knuckle…?
