jspangler22
I just replaced my coupler and mine is doing the rattling noise to
I had the alternator run on a tester at Advance Auto. It didn't make any noise whatsoever. I guess that leaves me with the A/C compressor. Is there a way to distinguish between a problem with the air gap between the clutch hub assembly and the clutch rotor and a problem with a bearing?
had this problem last week its your harmonic balancer. cheap part its also called your idler pulley if your getting noise its loose tighten it and if its broke they only cost 50$ its located infront of ur water pump
as i said
OK, so I replaced the harmonic balancer and the rattling sound is now gone. However, I now have a squealing/chirping/whining sound coming from the belt area. It didn't do it before I put the new balancer on. The sound gets louder as the RPMs increase, and after the car runs for 10 to 15 minutes, it seems to almost go away. Any suggestions? It does seem to go away somewhat also when I spray WD40 around the power steering pump pulley (which is new). Just seems weird.
