Re: Marofan's "GTX" Finally dropped on all 4's
So i've had quite the troublesome last 3 days with this damn car. Car was running just fantastic, pulled great, ran fne, no problems what so ever. Figured all right i'll pulley this thing. Went and got a puller from my buddy who had a GTX a few years back, he's since upgraded to a 2013 Gotta Have It Green Boss.
Pic is mandatory.
So anyway. Got the puller. Threw on my 3.4. Went to do a pull. NOPE. Not happening. Ran like absolute ****. I was rather dumbfounded. Didn't understand why. Used the aero to scan for codes. Nothin. Car just stumbled and ran like **** with any boost at all. Pulled the belt off and it ran fine for the most part. Threw the stock tune back in and no change. Swapped on the snout from my other blower with a stock pulley. Got better. But still stumbling and running like crap with any more than 2-3lbs.
Now was the time I discovered the aero has a misfire reading. Tons and tons of misfires. But still didn't help a whole lot. Well I was sitting at a stop light, on my way to get new plug wires, and I found another misfire screen that shows individual cylinders. Number 3 was the only one showing a miss. Okay, great. Plug or wire. Can't be a coil cause a coil would cause #3 and #6 both to miss since they're ran off the same coil.
So once I got home I let it cool for a bit and pulled #3 plug out and swapped in a new one. Yes I only swapped the one plug. I'm not freezing my ass of in 5* weather changing a whole set of plugs with it cold and windy. I did just the one to get it by temporarily until I do them all.
So I get the plug in and hook the wire back up and start the car and let it idle while I went back inside to look at the plug. At first I didn't see anything wrong with it. Looked fairly normal. But I was only looking at the electrode and ground strap.
Then I saw this...
So went and took the car for a drive. Runs MUCH MUCH better. Doesn't fall on its face anymore. It's still not 100% cause I broke a vac line and it has a leak, so I don't expect it to be 100%. But everything seems to fine.
So. After all of these plugs and wires get swapped out i'm going to try out that 3.4 again and see what happens.
