Leaking Coolant
seeth001
Hello,
I just bought a 2002 grandprix SE...i see that the coolant tank is losing coolant. I saw the green liquid on the bottom part of the engine? i am a little concered. Can anyone tell me what might be the problem?:confused:
wow..i dont want the head gasket to be leaking. anything else will not be that expensive if i am right. What are other things i can check to make sure it might/not be head gasket.
Thanks
Trace the leak as far as you can, it will help us help you.
Also, take deep breath. Since you actually see the coolant on the outside, it is most likely NOT a head gasket failure. So chill, it could be a $5 part that failed.:p
your mechanic could have just spilled some that ran down the motor when he was changing your fluids as well. I hope it is nothing....keep an eye on it for a couple weeks
