NebTurboST5
you guys are running awfully rich. i run my turbo car at 11.6-11.8 afr and have tuned several m90 cars at 12.0-12.2... without issue.
Fuel pump and or filter issues?
EGT's.
MPG's.
Sluggish throttle response.
Crap overall performance.
I personally never wanted to see less than 16* for a reason.
We arent in the gas long enough for EGT's to really matter than much.
MPG at WOT is for the lulz, I got 2.5 to 3 mpg if that.
How does throttle response relate to a timing figure below stock for WOT?? It's still going to pick up and go.
I didn't see a loss in performance with 13-15º, I ran there because it didn't knock. I'll take the 2 psi more in boost pressure and 1-3º less in timing and still make more power than stock.
Timing isn't everything but no doubt that in certain vehicles a higher timing figure would be sought after to make the most power possible. I know I refer to this alot but look at turbo'd LS motor, guys run 12-15º and still make 500+ WHP on under 12-14 lbs of boost on pump gas.
Agree, i seen a very noticeable difference from 13* to 18*.
Hptuners calculation (specifically the pulse width part) is wrong for all 04+ grand prix. It reads roughly 15% too high. I havent figured out the correct formula for it yet mostly because the information for it is not availible.He said my injector cycle was at 98% but I will confirm that with my HPTuners version . And if I would have been in the 240/270 range, no, this post wouldn't exsist. I suppose my goal for the post was to see if there is anything I'm missing that could explain the lower than expected numbers. Leaning it out to 11.5 might be an option .
I see no hard evidence on your side either.
