The Ripper973
I have a 2002 Gtp that's still has a bit of knock on the 3.4 pulley I'm running. I'm currently running the following supporting mods.
SD headers with a 3 inch zzp catback no cat.
K&N intake
NGK tr6 plugs gapped to 0.55
Zzp pcm tuned for 91 octane
When I'm in the boost I can see anywhere from 1-4 degrees of kr. Sometimes even cruising not in the boost I can see 1-2 degrees of kr if I'm on the gas a little. According to my aero force the A/F command says 11.2 and I'm running around 18 degrees of timing give or take. I do have a short stack intercooler I will be putting on and changing to a ported manifold and putting in a 180 thermostat. Just wondering if I'm missing anything that might help my current situation. Thanks Guys!
K&N intake
