Knightmare...over??
Re: The History of Knightmare(pic heavy)
Wish I could have found quad tips like those, but for the deal I got, I'm happy. The ride is looking great.
Ah so this would be your grand prix. Very nice! For some odd reason I feel like I have seen that coupe in dover a couple times before.
Thank you sir lol. You might have seen that coupe lol I have always frequented Dover. I really miss the rims on my first gp:-(
Sent from my SGH-I777 using Tapatalk 2
I have been thinking a lot lately....me and this GTP have been through a lot.
From cracked heads to bad ignition coils...to great times cruising. With the last couple weeks and moving. I don't have money to throw at it anymore. On the 2nd I had to replace an ignition coil after a bad misfire after replacing my lower radiator hose....here it is 11 days later and last night my temp started to rise again but only with speed, if I slowed down..it cooled...I checked my fluids and they are fine. I go to leave for work this morning and now its misfiring something fierce again :( I currently have it for sale as I believe our time, and my time with gps is over.
Edit:
Overheating is fixed and she got a new water pump and thermostat in the course of figuring out the problem. Gonna keep it and fix all the little crap.
My hvac doesnt work anymore, airbag light is on and my low coolant light is on as well as my check engine light which is for my o2 sensor at bank 1.
At least I know the problems with the GTP, if I get another used car, I don't know its history.
Oh joy...my wheel came off yesterday..... Leaving me without a car, without money to fix my car...and insurance won't cover it....guess its time for it to goto the junkyard... Pics included....
Why wouldn't they cover it? The exact thing happened to me a week ago and they covered me. What insurance do u have?
Sent from my HTC One using Tapatalk 2
Lol yup aftermarket bumper...and blue magic....didn't carry collision apparently... Thought I did, but I was wrong ....
Edit: I have GEICO
the rotor maybe good still, and all you really need are 5 new lug studs, at 2 bucks each, they dont cost to much.
remove the caliper and rotor. then you need a hammer and a punch to pound the old studs out. then use a grinder to cut one side of the new stud off so it clears behind the hub to get it in the stud hole.
then you put a lug nut on backwards, so its flat side is facing the hub, and tighten it, this will pull the stud into the hub. done.
then you can deal with the busted body parts. 10 to 12 bucks, and your driving again.
Hmmmm.....something to think about......
What about lower control arms n such?? Not sure what, if anything happened to any other components
looks like it rolled on the rotor, once you get it jacked up you know if anything else hit the ground. from your pics it looks like its a quick fix to just get it back up and driving.
your other option is to change the hub, they run about 130 tho.
I can tell you that my entire left front drug on the ground for a good probably 100 feet or so while I brought it to a stop...looks like everything is pushed up and back on that side
I would just do some new studs and see where you stand. If all is well then go ahead and drive it for while, if not either part it out, sell it to the jy. or sell it as a project to someone else.
