Manish1661
Hi Guys,
I am following all the steps and everything is going fine until the last step.
1) Close the doors
2) remove Mall PGM fuse
3) Turn Key to ACC - 3 chimes and flashing seatbelt light.
5) Off and back to ACC. - Here instruction says The BCM may begin to chime and flash diagnostic trouble codes. If BCM has stored any diagnostic trouble codes then refer to Diagnostic system check - Body control system.
4) Open any door door- Getting 1 chime confirming programming mode has been enteretd.
5) Close door - Getting 1 chime
6) Now if I press lock and unlock it doesn't give me chime after 7 seconds and no confirmation after 14 seconds. I have checked the remote with dealer and its active and working. I tried with another remote for 1999 grandprix but doesnt work. same problem.
Is it because of Diagnostic system check chimes? I am getting that in step 4. I have cleared all the codes and there r no codes in the system.
Any suggestions are highly appreciated. Thanks in advance.
1) Close the doors
