But that doesn't make it right.these cars misfire at idle. if its not causing any problems and all the ignition goodies are fine then who cares. my car always misfired at idle.
Mine is high mileage, too. 180k. As I said earlier, it seems to clear up to an acceptable level as the operating temp rises, which got me thinking about it being a "cold" plug and maybe I would bump the heat range on #4 up a little. Hard to figure an engine that operates "normally" close to 210F could have a cold cylinder though.i just kinda gave up on mine. it doesnt throw a code anymore. its almost not noticable and sometimes it doesnt happen at all. the only thing i can think of that i did was do something to the rear head when i had straight pipes. but yeah in case you are all wondering i never fixed it i just let it go... doesnt really bother me. 230k miles so i figured its a normal thing now
BUT... I have also recently noticed the miss comes back if I shut down and re-start...like on a trip to the store. That kinda tells me the problem might reside in the closed loop "warm up" cycle of the computer. So now I'm wondering if at some point these high mileage cars might need to be re-flashed. Anybody tried that? ~FH
No mods on this engine... that I know of. Just came out of a plug/wire/oil change. Just for giggles & grins I'll have the 'puter reflashed and see what happens.I wouldnt go mix matching heat range on plugs. These cars are notorius when moded at having mis and surging during closed loop operation. Some people have had luck with tuning.
OK... update to my last post...I can hear mine misfire at idle but my scans come up clean.
There's a difference between a sticky valve and something stuck TO the valve. 2 cans of Seafoam didn't faze it. Heads will be coming off. ~FHSticky valve...run some seafoam through that b1tch.
For realz.
