No homo always say no homo
all is normal like any other car, from like the 1000's of oil samples and oil filters we sent in to get tested, we found the car loves, shell t6 rotella oil. and believe it or not, of all OIL filters we tested....NAPA gold was the best hahaha 5/5 times.
the car responds to bolt on's well. BUT any drastic changes like anything you will need a MAF CAL. like i went from a short ram to cold air intake, and it threw my MAF cal off and i had to adjust it. but i mean that's when your deep in the game.
i made my own from scratch water to air incooler system. only thing i didnt make was the water lines and water pump.
i highly recommend the car, go test drive one, take off traction control and take off from second gear in a low RPM, that k04 action baby.
one of the con's is anything past exhaust/intake + boost, you need fuel internals, Fuel pressure must regulate above 1500 psi.
yea let me know if you ever consider getting one.
you very much can hear KR, if you get enough of it. sounds like rocks in a can.
ill pick up that sealant at autozone. I have maybe put 20 miles on the car since i have had it, just been moving it in and out of garage to work on customer cars and when im done pull it back in. couple trips around the block after installs make sure no leaks.
debating if i want to get new headlights, havent found any i like, i want projectors, but cant find a housing i like. tails as well, but all the designs out there are just way over thought and ricey to me, so smoked out stocks is what it'll need to be. need new GTPsupercharged emblems as well.
i replaced all the interior lights with 8 led lights, looks GREAT, just need to order the dome lights, pics to come this weekend. one of those strut body braces to the frame, i was taking them off to wire-brush and re-coat them and the head snapped off, so now i got tap it out.
97 08 Pontiac Grand Prix GTP 3 8L Supercharged Stainless Steel Header Exhaust | eBay
130ish after shipping but still....
only if you mean it.....
