Is my track time good
Get a scanner now, do not run again until you can monitor your KR, then take your stock PCM, put it back in, go get a dyno tune or have a member tune it properly for your mods. Then go run again. Also, driver mod.
Hey Russosaur... i just lookd up in zzp website and it says they dont lock there PCM
Sent from my GT-I9152 using Tapatalk
Well ZZP just has poo can tunes from what I've seen. Adecker is right dyno/in car tune is best. But Overkill I believe has the best can tune you can get.
Sent from my Galaxy Tab 3 8.0
Yep Will (Overkill) has the best can tune around!.. thats what i ran for a few years back when i first did my top-swap years ago, but once you start modding more, its time for and in-car tune(or dyno)
Overkill tunes are great.
Your 60 is lacking. That's probably why you pulled such a slow time. Get a scanner first and monitor knock. Then once that is sorted go to the track again and try to hook better.
Yea... im gna go next week and get it checkd for KR and get it tuned
some of what it does, some of these didnt work, so the list is smaller now.
Those ELM scanners are cool.. Right now im working on piggy backing data from the can bus using one I modified so I can change boost profiles and stuff with the steering wheel controls
