Tonkin2000GT
Something to do with pump failure causing it to go lean an blow up idk like I said I don't know alot about a methanol kitthat makes no sense at all
Sent from my SM-G920V using Tapatalk
Lol Scotty I'm running about the same pulley as you and you have a fsic? Wacked
your cam is the help. rockers are nice but dont flow as good as a cam. stock pulley i was seeing 6.5 boost, stock lim and gen 3, now ported lim ic and the 3.2 like 9 psi.
hit 12 with the 2.8 when i tried that one out for a while. that was knock free but it was also cold out. and i had to drop to much timing to run it too. so im back on the 3.2 till summer, then ill see what pulley i can run best in the heat of summer.
i got 5 pulleys to play with, 3.4 3.2 3.0 2.8 and 2.6 that will never be used lol
Yeah but my heads are ported ALOT, it's bored .020 over, zzp inlet and outlet porting to my gen 3 made it about a gen 5, and the motor is fresh I have a 3.4 and can probably go to a 3.3 with 18° timing 0kryour cam is the help. rockers are nice but dont flow as good as a cam. stock pulley i was seeing 6.5 boost, stock lim and gen 3, now ported lim ic and the 3.2 like 9 psi.
Lol I'm not running it on the serpentine belt it's setup like a gtp I'm using a SFI crank pulley 8 rib belt I didn't buy zzp's kit for that reasonquick question, do they make a ssm98 pulley smaller then a 3.4? iirc they dont get to small. looks like they hit the snout faster being they are off set.
Okay seems pretty easy so the meth tank is separate you mount it in the trunk how much meth does it hold? How much do you actually use? I'm assuming there are different jets or nozzles? What kinda gains? Pulley drop?you don't need bigger injectors or an upgraded fuel pump for methanol. if a fuel pump is going to fail, it will fail in the summer or winter. you need to learn to get information from other sources than zzp. that methanol kit for sale on the classifieds is complete. all you need to do is install it, fill the reservoir with methanol and go. some people say to lean the air fuel ratio, other people say not to, because when you inject methanol, your air fuel ratio will go rich.
Yeah what do you think about a methanol kit instead?When you have to choice to pick FS or SS , it's retarded to choose the SS. When your only choice is none or SS. Then I say SS
