Interesting.
Do you really want to be that guy who puts these on and finds out the valving is garbage?
You'll probably find your worn out bilsteins ride better/the same.
Ask bio about cheap coilovers.
I suppose. Someone else buy them then.
I mean realistically, if it came down to it, I guess one could buy different springs on Summit or something.
bet if you buy them, revalve them, and put better springs on them you'd have a better set of coilovers than you would have, for cheaper, than if you'd buy them from araut/HT/held.
This, springs are cheap, the revalving will probably be around $200 a set. Koni does rebuilds/revalving for $180 +parts
and i bet after being revalved you can probably get top of the line valving done and they'd be an awesome set of struts.
typically struts can be valved to handle a range of spring rates (say 6k-10k).
I still want my suspension to do it's job lol
This is so tempting. That's ideally what I would like to do. Springs are cheap enough.
Also, after looking at the thread below this one regarding coilovers, it looks like Drunkie suggests 200-300# springs. So, would new springs on these be necessary since they are 250#?
