Do you really want to be that guy who puts these on and finds out the valving is garbage?
You'll probably find your worn out bilsteins ride better/the same.
Ask bio about cheap coilovers.
250 lb springs. Eh.
But then the struts will not be right for the spring rates.
True. Well I suppose if someone else would like to take a stab at these, then we would all be curious. I doubt I'm going to be the one to do it.
bet if you buy them, revalve them, and put better springs on them you'd have a better set of coilovers than you would have, for cheaper, than if you'd buy them from araut/HT/held.
and i bet after being revalved you can probably get top of the line valving done and they'd be an awesome set of struts.
typically struts can be valved to handle a range of spring rates (say 6k-10k).
