Injector duty cycle
I have a 2005 impala l67,xp cam,gen v ,northstar tb,3.4 pulley,speed daddy headers,and my injector cycle was at 125 at wot and got 5*knock during high rmp and shift then it would drop down to 2* any suggestions?Oh i still have stock l67 injectors.;)
As I said in the other thread Any knock is bad even a few degrees. What tuning have you done and do you have someone who can tune the car for you?
Sent from my ADR6400L using Tapatalk 2
Ya but he said his tuner said the afr was around 12. That's kinda lean if that's true. With the xp it almost sounds like he can't get enough fuel at 125 inj duty.
I think it's fine i personally think your running out of injector and going lean. I can't see that without a scan though.
Don't forget you have to change your tune for those injectors. You just can't slap em on without doing anything to the computer. I'm sure you know this but i'm just telling you just in case ya know.
still seems rich 125% duty -- you're def running out of injectors though
The 04+ read incorrectly... He is still well within his functional range on that car... a 3.4 pulley with any cam will not max out stock injectors on any GTP... He can command a bit more fuel if he is really lean without hurting anything.
I imagine there is a bunk maf file on there that was loaded for the northstar that is leaning things out (because it was richened too much at idle).
You want around 11.5 afr for non intercooled and 12 for intercooled. In this case he's lean
