It might be your brake lock out switch has a broken wire. There is a little "button/cap" on right side of the shift housing near the front. If you pry that up it opens a slot that you can insert a screw driver and by pushing down (not too hard) will release the solenoid and turn the key. The proper fix is covered in different areas of the site and you can look that up for more details.
