HighOctaneRacing
I've got a code, P0053 HO2S Heater Resistance Bank 1 Sensor 1, I checked all the wiring and fuses and decided WTH the car has 104k on it I'll just replace the upstream O2 sensor. I did that yesterday and the code came back today. I got this code after I installed my overkill pcm 2 weeks ago. I think it might be the pcm but I found this, http://www.gpona.com/forums/04-08-grand-prix-discussion-f19/p0053-t25763.html.
The post says:
This was in the SM (under Document ID 1285788)
Heated Oxygen Sensor Resistance Learn Reset Notice
Notice: When replacing the HO2S perform the following:
• A code clear with a scan tool, regardless of whether or not a DTC is set
• HO2S heater resistance learn reset with a scan tool, where available
Perform the above in order to reset the HO2S resistance learned value and avoid possible HO2S failure.
I do NOT trust going to the dealer to do this because I'm afraid they'll re-flash my overkill pcm with stock tables. Is there anyone who might be willing to help me with this??
The post says:
