IC and Coil bracket from Bonneville
redlinepontiac
whos running a H body coil bracket for IC clearence? i have searched and couldnt find what year car you get that part from?
thanks in advance
Put a couple of nuts at the top between the ICM and bracket, brings the ICM up enough for belt clearance.
here im thinking of retrofitting dogbones into my park ave and someone wants to eliminate them. i chuckled slightly.
i wanted to switch to see about running the belt wrap assembly from WBS. it states it will not work with my current tensioner setup.
you will need to run an l36/l26 passenger side bracket if you want to keep that side of the motor from rocking. it requires you to drill and tap your head.
your other option is get a belt wrap kit, smoothflowpulleys sells a nice one, its $140 so thats in the price range of the coil bracket.
I'm pretty sure I have one laying around that I could sell. Won't be until the weekend that I could promise I can check but PM me if you're interested.
