how hard is it
well obviousy cam, oil, lim gaskets, supercharger gasket, TB gasket, timing cover gasket, coolant elbows, coolant. might be missin some stuff.
You have to go into the engine. Get some service manuals, or someone that has done it for help. It is not a beginner job...
NOT a beginner job at all. there are lots of things you can screw up in the process and unless you have experience or a few days of downtime for your car to go slow then i wouldnt recommend it.
any one in the town of cary or around bc i want to do it as a winter job like im only 16 but i know alot. but i would like some help threw it to do it right
you have two options...
1) Pull the motor out the top and install it...
OR
2) Drop the cradle a bit...remove passenger side tire, brake setup...remove front cover and crank pulley...install cam and reverse...
Not the easiest thing to do
ok this is what i got
-3'' down pipe
-ported manifold
-4'' pully for what i know
-soon to be no mufflers
im wanting to know what i can do. help me out im think for a fun winter project
Definatly not a beginer job Go with what they said intercooler rockers pulley headers will cost a bit more but isnt that bad since its all bolt on parts
