driving stick is real easy, the trick is to use as little gas pedal while letting the clutch up from a dead start. if your good you can get the car moving with no gas at all, then gas it and go, shifting gears, you let the gas go and push the clutch in at the same time shift gear let clutch back up and then back in the gas. you will be jerking the car till you get good at it, and then it will be smooth with practice.
the hard part for most new stick drivers after learning how to start with out stalling it or burning the clutch is forgetting to shift lol
down shifting witch is fun, is another lesson.
