How Do I install this?????
GTPJOE90
I just recieved a sweeeeet new oil pressure gauge via ebay. anyways the model number is 4327 its a autometer full electric oil pressure gauge with the sender. anyways im wondering how exactly do i hook up the sender?? all help would be apprciated thank you!! :th_thumbsup-wink:
nvm i figured it out u just unscrew the stock connector and throw this badboy i nthere haha thanks anyways :)
Im with bio! Ha its a pretty straight forward install! make sure u get the nut tight enough on the stud or it will back itself off
^^and to think...You frequent many forums and have several million posts at least. How much money do you think I would have??
a truck load LOL but seriously guys she is all wired up and snazzzzy what is the normal oil pressure on the 3800 l67 engine??? thanks
50 psi makes no sense. 50 psi WHEN? idle, cruise, WOT? they should all be different and within certain levels.
Typical when warm. I see about that when im warmed up and idling. When you hit the gas it normally shoots up to around 65 and stays, till i mash it and it goes to 80+
Good to know. Mine idles at around 50 and while driving it is around 70 so i guess mine is in the ballpark too. Thanks!
i always had crappy oil pressure. 35 psi when cruising, 50-60 WOT. all you NEED is 10 psi for every 1k RPM youre hitting, but its nice to have more.
