How Do I install this?????
yeah my psi is now 0............. its all wired up fine i triple checked..... theres no oil leak so wtf gives?
Ok i might sound dumb can you put these on a gt?
YES you most certainly can. I had one on my old 98 GT. The factory supplied oil sending unit indicator only warns you once the oil in your car is less than 5%, basically meaning kiss your engine goodbye warning. It is hooked up the same way on GTs as it is on GTPs.
Both model cars have the same 3800 series block, so the opening is located right above the passanger side driver axel at the end of the tranny. The Original sensor is GREEN in color, so it should not be hard to find.
I hope that helps
no its not a engine problem..... it was workin for about a hour yesturday drove it for liek 10 minutes parked it got up today going to work. as im going to work its at about 25 psi and im beating on it.. i park it turn it off start it back up and the needle doesnt move.................. i am stumped.......
I hope that helps
So all i do is it wire it into the sensor?
