horrible noise
OK sorry for no video but I will definitely have one tomorrow. It sounds like creaking and popping and only when Im going slow.
I'd take them apart and put them back together. Make sure everythings on right. Maybe the clip that holds the pads in is broken
so this noise is after you did the brakes, or just started to happen?
i'd take it apart and recheck everything, could be a cracked pad or something. either way.
yeah open them up, see whats going on in there, thats not healthy sounding at all.
if your getting a pull to one side or another when you hit the brakes and let the wheel go, but it goes straight when you are not on the brakes, you would defiantly have a problem.
Did you pull them back apart and recheck everything and grease the slides and where the pads sit?
