Hippo's Car - Install List Added Pg.23
Re: Hippo's Car - Future Mod List Added Pg.14
Just a tip when you install the poly dogbones save yourself a headache and just cut the rubber out and shove the poly one in. I spent a while trying to pull the rubber piece out and didn't get it, sawzall fixed it right up.
A tip with the upper dogbone bushings. Reno e the brass bushing from the poly. Lube with wd40 pop them in the dogbones than the brass bushing. save you a hassle
As far as removal I just cut the rubber lip with a razor blade and used a punch to knock.out the old rubber mount
Android Fire
Re: My Car is Fixed. Um. Yay.
Car is fixed yippee!! Here it is.
But its things like this, that piss me off. Do I go and tell the place that fixed it or what?
When you fixed this,
how?
and how has it held up
cause i just got a new bumper and its warped too
Lol I never did anything to fix it. I think it just went away, but I'll check it tomorrow.
zip tie the back side, kinda like a clamp is what i did on my old 99
get a heat gun and soften it up keep playing around with it it will take time but its possible.... and a question how do you change your thread name like how you said pics added page 14 how did you do that?
go to the original post and edit, advanced edit or whatever, then just change the titleeeee
Finally checked that out, the warp is almost completely gone, unnoticeable.
Think I may do an oil change tomorrow. Tranny and motor mounts Saturday. Any write ups on here for those??
Washed it yesterday, rubbed, polished, and waxed today.
Also went about getting those damn light bulbs out from behind the glove box.
Of course I ended up with a screw left over after re-installing.
And here's our dog haha
Also I got a Cobra XRS-9340 Radar Detector the other day, works nice, especially for the price!
Grand Prix Build List
"-" means I have it but not installed
"--" means I have it and its installed
Underlined items are my next buy
If you have any comments or suggestions lmk!
Aesthetics
SD Front Air Dam -$200
Window Tint- $225
--5" Arrowhead- $10
GPO Grilles- $125
6000k-8000k HID Fog Lights- $35
6000k-8000k HID Headlights- $35
-CCFL Projector Halo Headlights- $220
Black Arrowhead Overlay?- $20
New Rear View Mirror w/o Compass?- $55
--LED Reverse Lights- $12
--Tinted Tail Lights- $24
--Full LED Interior- $45
Performance
Ctek Premium Brake Pads- $40 WHAT DO YOU SUGGEST
R1 Concepts Slotted Rotors- $182
Stainless Steel Brake Lines- $135
Drop-In Struts- $300
ZZP Front Strut Tower Brace- $80
Energy Suspension Sway Bar Bushings and end-links- $25
Poly Motor Mounts- $60
--Poly Dogbone Bushings- $30
--Dorman Front Sway Bar- $110
GMPP Rear Sway Bar- $75
Open Cone Intake- $30
HV3 Intake Insert- $200
Water Pump Underdrive Pulley- $70
Magnetic Drain Plug- $7
Electronics
--Morel Maximo 5.25 Inch Component Speakers- $130
--Kicker KS69 6x9 Speakers- $90
--Kenwood 3-way 4-inch Speakers- $30
--Kenwood eXcelon X896 Headunit- $220
-Rockford Fosgate P3D2-12 12" Subwoofer- $120
Subwoofer Enclosure (building one)
-Pyramid TW44 Horn Tweeters 1"- $40
Alpine MRX-M50 Amplifier- $200
-Boston Acoustics GTA-802 Amplifier (2 channel)- $131
-Boss 8 Gauge Amp Wiring Kit- $16
--Cobra XRS-9340 Radar Detector- $60
--Monster iCable 800 Auxiliary Cable- $5
--Wolo Two-tone Horn- $20
Maintenance
-Transmission Mount- $20
-Motor Mount- $20
Pan Drop w/ Filter Change- $85
suggestions??
Re: Hippo's Car - Install List Added Pg.16
diy shift kit when you drop the trans pan
diy alt rewire
big 3
stage 1 volt booster
hood?
spoiler?
also add a switch to the remote wire to the sub amp for turning the big bass on and off
also 4 gauge power wires
gmpp strut tower braces and don rome brackets
/fractured thoughts
